BBK
23
  • Type Alfa: Alfa 159 1750 TBI SW
Subtle shakes or hiccips
« Gepost op: 24 oktober 2025, 14:58:52 »
Hi Everyone,
I could use some advice concerning my Alfa 159 1750 TBI.
Stationary the engine appears to run fine at plusminus 800 rpm.
I can feel hiccups or subtle shakes, but no loss of power when I drive with the rpm's steady, for example at 2500rpm in third gear with cruise control at 50 km/hr or on the highway with the cruise set at 100 km/hr with rpm's about 2000.
When I accelerate in whatever gear, the car is a beast with no hessitation.
There are no fault codes and I do not have a clue about what parameters/live data could tell me. I use a registered version of MultiECUscan.
Last week, I replaced the last two of my four injectors after injector nr.4 was leaking. All injectors have been tested and the manifold gaskets are new. New spark plugs, new bobines(ignition coils). Air filter is also new...and ofcourse new oil and filter...again.
Tomorrow I will receive a new gasket for the vacuum pump, It's leaking very little oil, no droplets but enough.
I have had on two occasions failed injectors and both times it started with a hiccup and then fumes and then loss of power. On both occasions the error codes came and I replaced them.
The hiccups raise my bloodpressure. Now lately,I've been driving with a lot of acceleration to trigger a fault code. Thus far no dice.
I'm under the impression that a vacuum leak would cause more evident  symptoms.
Can any of you help me trouble shoot?
Thanks for your time and Good weekend!
Dutchdriftking
732
Re: Subtle shakes or hiccips
« Reactie #1 Gepost op: 28 oktober 2025, 13:30:38 »
No fault codes, minor (but annoying) hiccups. What is the mileage on this car? With direct injected fuel carbon build up over time is quite a common issue. Maybe it needs walnut blasting?
BBK
23
« Reactie #2 Gepost op: 28 oktober 2025, 13:52:03 »
@Dutchdriftking
240K,  Do you recommend anyone, not to far from Amsterdam?  Thanks for your response!
Dutchdriftking
732
« Reactie #3 Gepost op: 28 oktober 2025, 16:41:28 »
I've been looking for one for quite some time. There are a few out there but none of them do diesel.... So, finally I found one that is willing to do my diesel, located in Rotterdam. They will do my car next month. I will share my experiences in my topic 😉
BBK
23
« Reactie #4 Gepost op: 28 oktober 2025, 20:10:31 »
thijsk89
206
  • Type Alfa: Alfa 147 JTD CUP
« Reactie #5 Gepost op: 28 oktober 2025, 21:53:23 »
What brand sparkplugs & coils did you get? The cam phasers are a known issue with the TBi engines as well (though strangely it seems more common on the later aluminium TBi 2014+ engine then the older ones), though this typically starts with poor starting cold, rough idle, perhaps even dying/stalling first time starting which you dont seem to experience.. Though with 240k's i can't imagine they are in the best of health..
BBK
23
« Reactie #6 Gepost op: 28 oktober 2025, 22:08:54 »
@thijsk89
ILKAR7D6G NGK plugs and the Coils are Bobine BAEQ230 Magneti Marelli, both coils and plugs  about 5 months old. Tomorrow I willreplace the seal on the vacuum pump. Thanks
thijsk89
206
« Reactie #7 Gepost op: 28 oktober 2025, 22:37:13 »
@thijsk89
In that case, there is a good chance it's because the coils. I have bad experience with these (albeit on a different fiat engine, 1.4 t-jet, but still). Why would you swap from the original Bosch to Magnetti Marelli? Original works best, same goes for the plugs..
« Reactie #8 Gepost op: 29 oktober 2025, 15:34:52 »
Yeah i agree replacing bobines to non oem ones can be a bit tricky.
If the originals were Bosch than it's probably better to stick with Bosch.
Some cars can be pretty sensitive for such kind of things.
BBK
23
« Reactie #9 Gepost op: 30 oktober 2025, 13:37:14 »
Yesterday I removed the vacuum pump and after a fair bit of cleaning, I installed a new seal I’ve driven 300 km just now, no more hiccups, no oil sweating. About  the coils, Magneti is fine. You just need the same brand when you replace jone. They don’t mix well
« Reactie #10 Gepost op: 31 oktober 2025, 18:29:52 »
Great that you got it fixed.
BBK
23
« Reactie #11 Gepost op: 31 oktober 2025, 20:28:46 »
@MysteryAngel Thanks! Good weekend!
