Harold
5.210
  • Type Alfa: Alfa Romeo 156
  • Ik ruleer...
    • Club Alfa Romeo
De oude Alfa Romeo Portello fabriek
« Gepost op: 8 november 2012, 21:30:46 »
Citaat
Photo was taken during the decade of 1960.The left side of the  facilities has already been demolished during the 80s.In the foreground  the facilities with the circular shape which follows the shape of the  square.In the background the south west suburbs of Milan.
The front of the facilities at the Accursio square
Warehouses.At the background the Style Center (Centro Stile)
The small road that leads to Via Renato Serra
The demolition of the Centro Stile & the Customer's service  facilities at Via Achille Papa 19, is about to beging (November 2001)
Demolition (November 2001)
Images of the Style Center  department (Centro Stile)
A 33 protoype.In the background the prototype of a 2 volumes C segment vehicle,which inspired the design of the 145.
The Cenro Stile was on the first floor.This department was active till the very last moment (1986).
An in house proposition by Centro Stile for the Alfa 164.
The 2 volume C segment was a design of Carli,Pininfarina's brother in   law.Never reached production,although it seems tha affected the design  of Alfa 145
One of the first prototypes of the 164 by Pininfarina
Prototype of the Alfa 33 FL
A closest look at the proposition of Centro Stile for the 164
Propositions for the rear end treatment of the Alfa 33 FL
Again in Centro Stile.A bounch of seats,bumpers,fascia etc.
Images of the R&D department
Gearbox  Test (see the soundproof on the wall)
Motor test.An early (1976)V6 Busso with 6 carburetors
Motor test.That's an Alfasud boxer with a single carburetor
Another 6 cylinder on the "banco prova"
Images of the experimental department and assembly line
This is the oldest department of Portello factory,where ing. Ravassi was testing the suspension and the body roll of the chassis
The assembly line,called "taparelle".The car is on the ground.This  method was used at the facilities of the North.On the other hand at the  facilities of Pomigliano (south)they were using the "bilancere"  method.The car was on the air,right in front of the arms of the worker.
Details of the experimental dept.
The main control for of the electricity
Another detail of the experimental dept.
Components of the oposition.Since 1976 Alfa studied the components that other manufacturers were used at their cars
On the first floor.Images of the exchibition dept
The assembly line of the 1900 berlina (1952)
The assembly line of Giulietta berlina (1954)
The body and carpenter dept.of the 6C Freccia d'oro (1947)
Addio vecchio Portello.
Re: De oude Alfa Romeo Portello fabriek
« Reactie #1 Gepost op: 9 november 2012, 09:07:06 »
Prachtige foto's die een 'dramatische' kijk geven op de historie....
reflection
155
  • Carve your successes into stone.
« Reactie #2 Gepost op: 13 november 2012, 20:00:12 »
Zeker prachtige fotos... Een brok in mijn keel!
Harold
5.210
  • Ik ruleer...
    • Club Alfa Romeo
« Reactie #3 Gepost op: 13 november 2012, 20:01:35 »
Ja, is wel mooi om te zien he.. Jammer dat het helemaal weg is.. zou leuk zijn om doorheen te lopen..
« Reactie #4 Gepost op: 13 november 2012, 20:06:48 »
Iets voor Job, Urbex :)
Harold
5.210
  • Ik ruleer...
    • Club Alfa Romeo
« Reactie #5 Gepost op: 13 november 2012, 20:07:49 »
Als je nu gaat loop je door de hal van het Fiero Milano.. hahahaha
« Reactie #6 Gepost op: 13 november 2012, 20:08:39 »
Met andere woorden, daar zijn we al geweest dus. En er staat een heel mooi stukje kunstwerk ter nagedachtenis aan de fabrieken  ;)
Jobo
1.821
  • Type Alfa: Alfa Romeo 156 1.9 JTD 8v
  • Luck is an attitude
    • http://www.urban-impressions.nl
« Reactie #7 Gepost op: 13 november 2012, 22:25:10 »
Jammer dat dit niet meer zo staat :-[
Heaven..... i'm in heaven.....  :D
Alfa Romeo 156 1.9 JTD 8v projectdiesel.
Origineel: 115 pk/ 275 nm
Inmiddels: 172 pk/375 nm
Doel: 175 pk/415 nm
Urban Impressions Fotografie
Scuderia Macchina Sportiva (SMS Racing)
