Seasonal car maintenance checks
« Gepost op: 6 december 2014, 04:28:17 »
Engine oil
     Oil plays an important efficacy relies on an important feature - viscosity oil has a viscosity characteristics can only operate various parts of the engine parts to provide a protective film. The viscosity is generally referred to the physical properties of the oil, which was intended to ease the degree of fluid or semi-fluid flow, that is often said that "thick" or "daughter in law. High viscosity, flow speed is slow.
     SAE viscosity grade oil by the oil car oil operation identifies the minimum and maximum temperatures. Special type of engine Benz Turbocharger oil temperature environment label has: SAEOW, SAEl5W, SAE20W etc., SAE, said after the W winter, figures also indicate viscosity, the smaller the number the lower the viscosity. This type of oil used in the winter cold, the lower the oil viscosity, the greater the speed of the engine start; at the same time lower the pour point of the oil, the easier the oil is pumped, can more quickly reach the lubrication and shorten parts dry friction time. Before the digital W becomes smaller, the better the fluidity of the lubricating oil at low temperatures, the easier the automobile cold start. Choose good Mitsubishi adjustable Coilovers
     Winter cold winter if the label is not enough oil, it will lead to easy flow, so when you start the car engine will be seriously damaged, so every owner before the onset of winter should check their car oil is too resistant to winter.
Recommend blog http://carsspeeding.weebly.com
