Masso
639
  • Type Alfa: 156 GTA formerly 2.5V624v
  • Echte mannen hebben geen tang nodig...
Re: Geen GTA, wel GTA motor
« Reactie #30 Gepost op: 27 mei 2014, 17:37:00 »
No worries, been busy too.
Wow wow wow gorgeous pistons!  O:-)
Echte mannen hebben geen tang nodig....
turbonutter
25
  • Type Alfa: Stratos Turbo
« Reactie #31 Gepost op: 27 mei 2014, 18:29:35 »
Its a shame to put them in the engine - they will never look so shiny again!
Masso
639
« Reactie #32 Gepost op: 27 mei 2014, 20:17:41 »
« Reactie #33 Gepost op: 27 mei 2014, 21:27:33 »
Indeed.
But you have the pictures and in the end...pistons are needed in the engine!
Jobo
1.821
  • Type Alfa: Alfa Romeo 156 1.9 JTD 8v
  • Luck is an attitude
    • http://www.urban-impressions.nl
« Reactie #34 Gepost op: 28 mei 2014, 09:24:42 »
Wow, those pistons looking great!!  :13:
Alfa Romeo 156 1.9 JTD 8v projectdiesel.
Origineel: 115 pk/ 275 nm
Inmiddels: 172 pk/375 nm
Doel: 175 pk/415 nm
Urban Impressions Fotografie
Scuderia Macchina Sportiva (SMS Racing)
turbonutter
25
« Reactie #35 Gepost op: 28 mei 2014, 09:51:11 »
They are designed and supplied by Performance unlimited here in the UK, but made by CP in the USA.
These ones are to be fitted with Total Seal Rings & have Cailco Skirt Coating...
M.van.MaarenGTA
92
  • Type Alfa: 147 GTA 3.2 V6
« Reactie #36 Gepost op: 20 juni 2014, 01:03:48 »
Very nice project this is!
Masso
639
« Reactie #37 Gepost op: 2 juli 2014, 19:06:13 »
Any progress, Neill?
turbonutter
25
« Reactie #38 Gepost op: 10 juli 2014, 00:54:34 »
No Progress on the engine.... Well I have now had the liners machined and the Stainless o-rings installed & the pistons are back from balancing, they now all weigh the same as the first set of pistons, so there will be no need to rebalance the whole engine assembly :)
I havent started the rebuild, as I want to finish the other jobs on the car first. I have had a mock loom for the engine made from string & my new Tuner is making up the loom for the new ECU.
I havent been idle, & have finished the wiring changes that I need to do & I have mounted sensors for traction control, as well as remaking various water pipes for the engine and charge cooler.
The Gear Lever I have fabricated is finaly finished and back from the Anodisers & Powder Coaters......................
I have also been working installing new sensors fro the New ECU Both For Control and Logging.
Fuel Pressure, 3 EGT Sensors 2 LAmbda Sensors Charge Cooling air and water sensors ETC & have a new throttle pedal hooked up the a vauxhall throttle Pedal Pot..
Masso
639
« Reactie #39 Gepost op: 10 juli 2014, 01:17:03 »
Outstanding work
marvin-1989
29
  • Type Alfa: 166 2.5 V6 24V NERO601
  • voorheen 156 1.8 ts nu 166 2.5 v6 24v
« Reactie #40 Gepost op: 15 juli 2014, 23:19:21 »
great project to follow! what an outstanding peace of art. :PDT_Armataz_01_37: very cool to take an also italian v6 alfa-romeo busso engine for this car! i always loved that one of a kind design that was given to the stratos! very lovely! :dance:
keep up the good work!  :You_Rock_Emoticon:
een vrouw en een fiets is altijd iets
turbonutter
25
« Reactie #41 Gepost op: 23 juli 2014, 23:37:30 »
Well Finally the engine is rebuilt, The heads have been skimmed and the liners have a stainless 1mm wire o-ring installed in the top face.. Liners honed, new pistons & total seal rings.
Coil on Plug are Audi R8 Coils with alloy adaptors I made (I cant get the Alfa coils in due to the charge cooler and having the plenum on the other head...
Unfortunately it is now time for me to go back to work, so that is it until October...
On the plus side my new tuner will have 2 months to make uo the new engine loom......
M.van.MaarenGTA
92
« Reactie #42 Gepost op: 26 juli 2014, 01:28:08 »
Looks stunming
Masso
639
« Reactie #43 Gepost op: 15 augustus 2014, 16:38:07 »
 :You_Rock_Emoticon:
2.630
« Reactie #44 Gepost op: 15 augustus 2014, 18:02:31 »
Nice !  :sign0098:
