2.687
updates : Campaigns 6116, 6117, 6118
« Gepost op: 12 april 2017, 18:46:54 »
Kwam op Engels forum bijgaand bericht tegen van iemand die nogal veel weet van Giulia (werkt vermoedelijk bij Alfa  ;D )
Citaat van: MacGeek
Since there's a lot of interest in the matter, I thought I'd explain briefly what's up.
Alfa Romeo recently issued three Service Campaigns for the Giulia, for all engine options. Campaign 6116 is for the 2.2 diesel, 6117 is for the Quadrifoglio, and 6118 is for the 2.0 petrol.
So, what's up? Should I freak out? Do I go camp in front of the dealer right now?
Don't worry. Think of Campaigns 6116, 6117 and 6118 as "Giulia Service Pack 1": The bulk consists of software updates, for many of the control units in the car, plus a few physical checks. All owners of affected cars will be notified by mail.
I can't wait for that, the suspense is killing me! Tell me right now!
If you have a 2.2 diesel, you're affected if your chassis number ranges from 7510665 to 7539942. The affected chassis numbers for the Quadrifoglio are between 7510677 and 7537597, while the 2.0 petrols included in the campaign range from 7510836 to 7537599.
What's in them?
The three Campaigns are mostly identical, just some physical checks are specific to one of the engine options. Keep in mind that just because your car is affected, it doesn't necessarily mean you need all the updates/operation I'm going to list here. The dealer will be able to tell, by entering your chassis number in their system, what exactly applies to your specific Giulia. Here's the details.
Physical Operations
  • Check torque settings of front differential mounting bolts (Q4 versions only)
  • Replace side mirror caps (some very early cars exhibited paint adhesion issues: rather than just repaint, all mirrors coming from the same production lot will be completely replaced)
  • Check torque setting of upper catalytic converter mounting bolts (2.0 petrol only)
  • Check positioning of electrical cabling behind offside front wing (Quadrifoglio only)
  • Check positioning of high pressure pump connector (Quadrifoglio only)
  • Check position of coolant level sensor (Quadrifoglio only)
  • Check for interference between A/C circuit quick connector and coolant pipe (Quadrifoglio only)
Software Updates (applies to all three campaigns, unless specified)
  • Electronic Steering Lock Module
  • Body Computer Module
  • RF module (controls keyless entry/start and TPMS)
  • Brake System Module
  • Instrument Cluster Module
  • Chassis Domain Control Module (cars with active suspension, option code SDD)
  • Adaptive Cruise Control Module
  • Front Camera Module (for LDW/FCW/Auto High Beams - on some very early cars the module will need to be replaced, rather than just reflashed)
  • HVAC Module
  • Electronic Power Steering Module
  • Park Assist Module
  • Engine Control Module(s)
  • Transmission Control Module (only on 2.2 JTD and Quadrifoglio)
  • Infotainment Module
  • Sat Nav map update
SchumiF1
34
  • Type Alfa: Giulia Super 2.2 JTDM
Re: updates : Campaigns 6116, 6117, 6118
« Reactie #1 Gepost op: 15 april 2017, 08:44:45 »
Bedankt mooie info  :sign0098:
Martini8v
94
  • Type Alfa: Giulia 2.2 JTDm 8ATM
    • Foto site
uU
« Reactie #2 Gepost op: 24 april 2017, 10:14:24 »
Krijg net de brief met uitnodiging voor Kwalitateitscontrolle 6092 en Software update 6116 binnen. (2.2 Diesel 180pk AT8).
