« Gepost op: 27 juli 2019, 10:41:07 »
Published today, for incorrect fuel level readings in specific conditions.
The specific conditions include being parked on a grade of more than 10 degrees, staying in that position for a long enough period of time (approx. 30 minutes), and having a tank filled between 50-75%. At this point, the vehicle will think it went through a refuel and add a notch or two to the fuel gauge upon restart. This additional fuel reading will persist until an actual refuel takes place; after which, the fuel reading will be accurate once again.
Fix is a software update. It will be made available sometime in the 3rd quarter.
https://www.giuliaforums.com/threads/recall-v84-fuel-level-display.46120/In Europa: Campagne 8242
Blijft allemaal software
Gelogd
