2.620
nieuwe verse MES, 4.2, nu V 4.4
« Gepost op: 17 augustus 2018, 15:24:19 »
Is ook weer een nieuwe versie uit van MultiEcuScan, versie 4.2
17/08/2018 - Multiecuscan 4.2 Download
- Added information for more ISO codes from 2012-2018 vehicles
- Fixed a problem with DRL activation on some Freemonts
- Fixed problem with CAN Monitor date/time setting of Alfa 159, Bravo, Delta, Croma
- Added new PROXI configuration options for 500X, Renegade and Giulia
- Improved SCAN function to find more modules in 500X, Renegade, Giulia, Stelvio
- Support for Magneti Marelli IAW 8GMB CF5/EOBD Injection (1.4) (500)
- Support for Magneti Marelli IAW 9GF CF6/EOBD Injection (1.2, 1.4) (Fiorino, Qubo)
- Support for Magneti Marelli IAW 9GF CF6/EOBD Natural Power Injection (1.4 CNG) (Fiorino, Qubo)
- Support for Marelli 9DF CF6/EOBD Diesel Injection (1.3) (Fiorino, Qubo)
- Support for Body Computer Marelli (949) (Stelvio)
- Support for CAN Setup / PROXI Alignment Procedure (949) (Stelvio)
- Support for Blind Spot Sensor Autoliv (Giulia, Stelvio)
- Support for Amplifier module Ask/Beats (Giulia, Stelvio)
- Support for Automotive Lighting adaptive headlights (Giulia, Stelvio)
- Support for Adaptive cruise control Bosch ACC (Stilo, Thesis)
2.620
Re: nieuwe verse MES, 4.2, nu 4.4
« Reactie #1 Gepost op: 10 maart 2019, 10:50:32 »
Zojuist versie 4.4 uitgebracht ;)
08/03/2019 - Multiecuscan 4.4 Download
- Added information for more ISO codes from 2015-2018 vehicles
- Added support for Jeep Compass
- Added new PROXI configuration options for 500X, Renegade, Giulia, Stelvio, 500L
- Fixed incorrect decoding of some country codes in 500X, Renegade, Giulia, Stelvio PROXI configuration options
- Support for Bosch EDC17C69 CF6+ Diesel Injection (1.6, 2.0) (Compass)
- Support for Magneti Marelli IAW 8GML CF6 Injection (1.4) (Compass)
- Support for ZF 9HP48/948TE Automatic Gearbox (Compass)
- Support for Continental ABS/ESP/EPB (Compass)
- Support for Instrument Panel Marelli (MP) (Compass)
- Support for Body Computer Marelli (MP) (Compass)
- Support for TRW climate control (Automatic) (Compass)
- Support for Parking control with SPM Bosch (Compass)
- Support for Continental Airbag (Compass)
- Support for Comfort seat and wheel (CSWM) Continental (Compass)
- Support for Service Interval Reset (MP) (Compass)
- Support for CAN Setup / PROXI Alignment Procedure (MP) (Compass)
- Support for Magneti Marelli IAW 10GF CF6 Injection (1.0 GSE) (Uno 2015)
- Support for Uconnect Radio/Nav 5" (500X, Renegade, Tipo, Egea)
- Support for Uconnect Radio/Nav 6.5" (500X, Renegade)
Klavertje7
133
  • Type Alfa: busje komt zo
Re: nieuwe verse MES, 4.2, nu V 4.4
« Reactie #2 Gepost op: 22 maart 2019, 20:42:51 »
Hallo Jwq,
Heb even een vraagje.. zou mijn Alfa ook graag s willen updaten.. heb jij een idee hoe dat moet? Alvast vriendelijk dank
Timon
413
« Reactie #3 Gepost op: 23 maart 2019, 11:50:07 »
Same here. En dan met name of de tct up to date is...
2.620
« Reactie #4 Gepost op: 23 maart 2019, 11:59:07 »
Hallo Jwq,
Klavertje7
133
« Reactie #5 Gepost op: 23 maart 2019, 12:42:06 »
Hallo jwq,
Dank voor je onderbouwende antwoord. Dan zal ik eerdaags even langs de
dealer rijden...
Mvg. Marcel
twido
38
  • Type Alfa: Giulia veloce Q4 2.2 JTD
« Reactie #6 Gepost op: 30 maart 2019, 22:16:04 »
Kan helaas? alleen via de dealer, als je de software voor de auto (giulia, stelvio) bedoeld.... Zijn wel wat updates voor infotainment, maar alleen de vroege versies. Enige dat je officieel zelf kunt updaten is de kaart software voor de navigatie van de giulia/stelvio
De in dit topic genoemde MES software is alleen bedoeld om je OBD poort uit te kunnen lezen, zaken te testen, reset fouten etc., dus alleen test tool
[/quote]
En hoe kan je dan de navigatie updaten? Want daar heb ik nog niet veel over gevonden eigenlijk.
2.620
« Reactie #7 Gepost op: 31 maart 2019, 08:45:45 »
[/quote]
In theorie kan dat gewoon via het menu op de infotainment, is een optie firmware update. Gaat op dezelfde manier als de kaarten: file(s) op usb stick plaatsen, inprikken en voor update kiezen. Update duurt ca 15 minuten, waarbij de auto wel stationair moet staan.
Zijn 2 versies van het infotainment systeem, versie van voor begin 2018, en versies na begin 2018. Deze hebben verschillende processoren etc., als is de werking en look-and-feel hetzelfde.
Versies zijn te herkennen aan de firmware versie die je ook op het systeem via menu kunt lezen,  oude versies zijn genummerd 001.xxx.xxx of 002.xxx.xxx,  de nieuwe versies zijn genummerd 051.xxx.xxx, 056.xxx.xxx etc.etc. Firmware is niet uitwisselbaar tussen oud en nieuw, maar foute firmware wordt ook niet geaccepteerd door systeem.
Gedurende eerste jaar of zo kon je de software downloaden via de mopar server, maar dit is op een gegeven moment geblokkeerd door Alfa.
Laatste versies die nog voor "gewone" gebruiker beschikbaar zijn is 002.009.055 voor oude systemen, en 056.000.007 voor nieuwe systemen....
