2.630
versnellingsbak in neutraal
« Gepost op: 1 oktober 2018, 15:21:13 »
Kwam bijgaand onderwerp nog tegen vwb het in neutraal zetten van de automatische bak, in geval van wegslepen, of (niet aan te raden ;) ) automatische autowas.
Je weet nooit of het nog eens nodig is.
<snip>
I just tested in on my 2017 QV and it works just fine. Put car in Neutral, turn off with start/stop, car stays in Neutral. Open door, car still in Neutral. Remove foot brake, and car starts to free roll. I even get a warning on console that car is not parked and safety off.
Goes back into P after 15 minutes.
https://www.giuliaforums.com/forum/289-alfa-romeo-giulia-general-discussion/38506-unlocking-automatic-transmission.html
en:
Citaat van: MacGeek;651090
It's done from outside, under the car. You need to screw in a M6x1x32,3 screw (available from Alfa Romeo with part number 55280980) on the side of the gearbox.
https://www.youtube.com/watch?v=3zS0mtgrBZM
